Obs den In Deutschland geben wird weiß ich nicht !
Specifications Foresight (ED-type)
Engine
Type Liquid-cooled 4-stroke OHC single
Displacement 249.4cm3
Bore x Stroke 72.7 x 60mm
Compression Ratio 10.5 : 1
Max. Power Output 14.1kW/7,000min-1 (95/1/EC)
Max. Torque 21Nm/5,500min-1 (95/1/EC)
Fuel System
Carburation 30mm CV-type carburettor
Fuel Tank Capacity 12 litres
Electrical System
Ignition System Fully transistorised electronic
Starter Electric
Drivetrain
Transmission Type V-Matic
Chassis
Dimensions (LxWxH) 2,070 x 735 x 1,425mm
Wheelbase 1,450mm
Seat Height 745mm
Ground Clearance 140mm
Dry Weight 158.9kg
Suspension
Type Front 33mm telescopic fork, 88.7mm axle travel
Rear Single damper unit swingarm, 96.2mm axle travel
Wheels
Type Front 12 x MT2.75 U-section 5-spoke cast aluminium
Rear 12 x MT3.50 U-section 5-spoke cast aluminium
Tyre Size Front 110/90–12 64L
Rear 130/70–12 62L
2005 FORESIGHT - E3
Brakes
Type Front 240mm hydraulic disc with Combined 3-piston calliper,
drilled rotor and resin mould pads
Rear 220mm hydraulic disc with single-piston calliper and resin
mould pads
All specifications are provisional and subject to change without notice.
