So a first service should be at 1000 km.
And then it's every 6000 km.
So the second should be at 6000 km or 7000 km?
I think I saw my cluster is set to 7000 km.
It's not really clear for me looking into the intervals table.
Not in my topic because i think it's useful general knowledge
1000,6000,12000,18000,24000,....
Ok, so I have just double checked.
I have right now 1700 km on the cluster.
And it shows me 5300 km to service.
So it's set to 7000 km.
I guess the dealer does not set the interval, they just reset it?
On my quite comparable 2019 Vision 110 the plan says:
1000 km "change oil, check idle speed". Nothing else.
6000 km "change oil (yes, then it's only 5000km old), clean Kurbelgehäuseentlüftung, check valve clearance, check spark plug, check brake fluid, check brake pads, check if holding brake is working, check main light adjustment, check side stand, check wheel suspension" and a lot more.
There is no reason why all these things should be 7000km, except change oil, after purchase only if it is the first maintenance and after 6000km for all the following inspection dates.
I don't know what honda or your dealer was thinking to set the 6000km inspection to 7000km.
